Circuit that converts 110Vdc to 24Vdc
smb
Member level 2
convert 110vdc to 24vdc
Is there any simple and small circuit which I can convert 110Vdc to 24Vdc(50mA)?
Re: 110Vdc to 24Vdc
use a & capitor-filter
u will get 35VDC o/p
use a maxim/LT linear regulator
Re: 110Vdc to 24Vdc
You can try a 1.5kΩ/7W resistor and 24V zener diode ..
This resistor will be "warm", but, if you can afford to loose some energy as heat, that is the easiest way of 110Vdc to 24V dc conversion ..
Regards,
IanP
