circuit schematic of an SRAM Array
electronics20
Full Member level 1
Full Member level 1
Hi
I need a circuit schematic of an SRAM array. I did not find anything on the internet!
Thanks
Google finds for "sram array design" a lot of stuff, including PDF file which I won't link here because of bad forum rules, sorry.
You can do it yourself though.
That's true. But in many cases, input and output names were not shown clearly in these PDF files. For instance, my main question is that which signals are as the inputs of MUX used in SRAM array?
Thanks again
Forum policy prefers we create Edaboard attachments if we are posting our own images, schematics, pdf's, projects, etc.
It is okay to give links to material at websites, if it is publicly available, and if we can expect the links to remain valid.
These policies have a certain amount of leeway, for individual cases which arise.
For data IO only you don't need a MUX, just a switch-over signal from input to output and vice versa.
For row- and column decoding see the standard peripheral circuits' descriptions for any RAMs, e.g. the following one for SRAM address decoders: View attachment 115839
Thanks. But suppose having a 32*32 SRAM array. If each column delivers one bit to output, array must have a MUX to select one output data associated with that selected cell. Is it true?
It doesn't matter if you call it decoder or MUX, it's just the same. For different architectures, s. pp. 2 & 3 of the above overview paper.
Does each column of an SRAM array need one sense amplifier? i.e 8 columns need 8 sense amplifier circuitry?
Thanks
The answer is on page 3 of the , paragraph Sense Amplifier:
number of sense amplifier is equal to number of columns ...
Those who are able to read
Are at an advantage, indeed.
