Circuit for detecting 110v and 220v
simo
Junior Member level 2
usa
hi
i have a sysytem works with linear power supply,but i have a problem to switch from 110 to 220v .
i need a shematic that can know electronically 110 v or 220 v,like the LED will turn on if the voltege is 220v .
pleas if anyone has this shematic for that circuit send it to me
regard
220v detector schematic
I think it's really easy to do...
Take a look of the following circuit. Hope it can help.
Wenye
220v detect
thank you very much for your reply.
this is the circuit iam looking for thanks again
i need the real vulue of the componant that you use in that circuit
regard
110v/220v switch diagram
But we are speaking of detecting 110v or abouve. Or one bit logic to tell in the line existes 110v, and another bit logic to tell the presence of 230v?
NeuralC
Re: 110v/220v detector
thank you for your reply
but the schematic we have doesnt show any values of the componanant used on it.what bits do you mean,i do need the circuit can detect 110v AND 220v .pleas if you have any other circuit send it to me
thank you very much guys for your help
help!!
any adea guys
pleas if you have any adea about he assue above send it to me
thanks
Hi
I have one idea is use peak detect (the circuit can be use by
diode + Cap) ,
how you make a peak detector
do you have any accurate schematic??
pleas send it to me
regards
You want an optoisolated one? or not optoisolated?
//a
hi
optoisolated or not doesnt matter
you can send me both if you have them pleas.
regards
I will draw in the weekend a schematic for you!
best,
//a
thank you very much sonic
that is the shematic i was looking for
thanks again
