circuit for Bandpass filter
gr8_halem
does anyone know where i can find a circuit for Bandpass filter?? freq range 2.3G-2.5GHz bw 200MHz
what specification of this filter that you want?
what implementation you want it: cavity, lumped, transmision line????
David
well there's many implementations depending on your specs and applications
like coupled lines capacitive gaps zigzag filters hairpin resonators filter
and comblines
read pozar and mathaei for background also microstrip filter jia sheng hond and lancaster
or if you need a fast design try the ADS design guides
There's a good literature from Microwave Engineering 2nd Ed written by David Pozar.
You can refer to chapter 8 for more example. I alway preferred the coupled line design approach but you can still design using lumped element with this frequency.
You can simulate and optimized the result using ADS.
Goodluck...
Get the Ansoft Designer SV2. It is students version & free. try designing different filters there.
You can find via Internet an evaluation copy of the Nuhertz Technologies software - Filter Solutions.
Use Genesys has good Filter Synthesis tools
E. Sánchez-Sinencio's notes will help u!:D
I've used this program and I think it's one of the best there is.
Very easy to build your filters. I'm sure it would help you. However you should get some literature about filters and their specifications.
I thins the Filter design guide of ADS is a good start.
