CIC filter verilog code
sssliz
Newbie level 6
Asia
hi,, i am doing a project on SOFTWARE DEFINED RADIO in which i am using a CIC filter which is implemented in FPGA.And hence i need to write a verilog code for cic.can u help me with a simple code please......:-(
There are several Verilog CIC examples in previous threads, just search edaboard. I'm writing this stuff in VHDL, thus I can't give you any examples. You are welcome with specific questions related to your code, however.
Reactions: sssliz
    sssliz
// cic decimation filter : R=64, M=1, N=3
module cicdecim64 (x_in,y_out,clk,reset);
input clk,reset;
input [7:0] x_in;
output [7:0] y_out;
parameter hold=0, sample=1;
reg state; //sample or hold states
reg [5:0] count; //count till 63 starting from 0
reg [7:0] x; //input
wire [23:0] sx; //sign extended input
reg [23:0] i0; //Integrator output section 0
reg [18:0] i1; //output section 1 under the consideration of Haugenauer's pruning
reg [13:0] i2;
reg [11:0] i2d1, c1, c0; // Integrator+COMB 0
reg [10:0] c1d1, c2;
reg [9:0] c2d1, c3;
always @(negedge clk)
begin : FSM // finite state machine
case (state)
hold : begin
if (count<63) // setting states for downsampling
state <= hold;
else
state <=sample;
end
default:
state <= hold;
endcase
end
assign sx={{16{x[7]}},x_in};
// Integrator
always @(posedge clk)begin
if(reset) begin
i0 <= 24'd0;
i1 <= 19'd0;
i2 <= 14'd0;
x <= 8'd0;
end
else
x <= x_in;
i0 <= i0+sx;
i1 <= i1+i0[23:7];
i2 <= i2+i1[18:5];
case (state) //downsample
sample : begin
c0 <= i2[13:1];
count <= 0; //reset counter once a sample has been fetched
end
default :
count <= count+1;
endcase
end
// COMB
begin: COMB
i2d1 <= c0;
c1 <= c0-i2d1;
c1d1 <= c1[11:1];
c2 <= c1[11:1]-c1d1;
c2d1 <= c2[10:1];
c3 <= c2[10:1]-c2d1;
end
assign y_out=c3[9:2];
endmodule
Test bench
`timescale 1ns/1ps
module test;
reg clk,reset;
reg [7:0] x;
wire [7:0] y;
cicdecim64 cic (x,y,clk,reset);
initial begin
x <=8'd1;
clk<=1'b0;
reset <= 1'b0;
#4 reset=~reset;
#5 reset=~reset;
end
always
#4 clk=~clk;
endmodule
I found this cic code from previous threads.there are no errors when complied.but there is no change in the output y_out variable.Can u just help me out with this please?
cicdecim64 has serious implementation errors. The comb section must be run at the downsampled rate, under the condition if (state == sample).
P.S.: I just found, that the code is a slightly modified copy of the CIC Verilog code in Digital Signal Processing with FPGA by U. Meyer-Baese.
But in the original code, except for different decimation factors and word width, the comb section is operated at the low rate.
  begin : Comb
    if (state == sample) begin
      c0   <= i2[15:2];
      i2d1 <= c0;
      i2d2 <= i2d1;
      c1   <= c0 - i2d2;
      c1d1 <= c1[13:1];
      c1d2 <= c1d1;
      c2   <= c1[13:1] - c1d2;
      c2d1 <= c2[12:1];
      c2d2 <= c2d1;
      c3   <= c2[12:1] - c2d2;
    end
  end
Conclusion better refer to a good text book.
hai
we got the vhdl code for NCO....so can u help us with vhdl code for cic filter ??
thanks
Can you give me the code of CIC filter in Vhdl...I am learning on a topic "implementing cic filter for software defined radio applications"...Please if you coiuld reply asap.
