icydash
Newbie level 6
Hi! So I'm trying to design a circuit where on one end, if i hit a regular push button switch, it causes a wireless signal (maybe the word "turned on" if the switch is on, or "turned off" if the switch is off, using perhaps a zigbee?) to be sent to a wireless receiver on the other end. The wireless receiver then sends the data to a microcontroller, which decides what to do based on if it receives the "turned on" or "turned off" signal.
If it's "turned on," the microcontroller will allow a [guitar signal] to be conducted through one wire/path, and if it's "turned off" it will direct the guitar signal through a default path (another wire).
I'm not sure what microcontroller to use. I want the receiving end to fit in the smallest possible case. Literally, if I can do the whole thing in something the size of my thumb, etc, that would be fantastic. I was hoping people could provide me with easy to use microcontroller options, etc. That would be extremely useful since I'm not that aware of what's out there. Since the processor is doing minimal work, nothing fancy is needed. The simpler the better. I guess the smallest microcontroller unit that is still solderable and easy to prototype with is what i'm looking for. Cost / money is not an issue.
Thanks so much!
PS. If you have any good ideas about a wireless chip to use, too, that would be extremely helpful. Is there anything more suited to this kind of application than a zigbee (this is all i know of)?
Thanks so much!
