AlienCircuits
Member level 5
Hello, be prepared for a lot of naive questions.
I'd like to use a "choke" inductor as my conversion inductor (as opposed to EMI filter) in a boost PFC design. I've never made a boost PFC converter before, so I am unsure if I'm making the right choice with this inductor.
My PFC will take line voltage from 70 to 140 VAC and convert it to 210 VDC @ 26 watts. I wanted to minimize ripple current, and so I tried to find as big of an inductor as I could in the right price/current rating/environment range.
I found this:
https://www.epcos.com/inf/30/db/ind_2008/b82721a_j_k.pdf
Part number B82721A2122N020 (6.8mH 1.2A per winding)
Now, my confusion is that this is a choke inductor. Does this imply that it is not designed to be in the converter process, but just as a common mode choke for EMI? If I connect the 2 windings in parallel, I will have 3.4mH with a 2.4A rating, but then I am unsure if the common mode configuration will have negative effects on the 100kHz switched current into it. What if I connect them in series? To increase my buying power, would using the same part for both my EMI choke filter and my conversion inductor be feasible?
I found this:
