chipscope output in LCD
ammassk
Member level 2
Member level 2
DEAR ALL
I need a solution to interface LCD with CHipscope. Input values to chipscope are a set of 8 values each with 16 bits and output 8 bit is got . How to display this chipscope output in LCD of FPGA?
....Some one please respond for this.
As far as I'm aware of, Chipscope isn't designed to use other host interface than JTAG. To sample a number of fixed data points and process the data in the FPGA logic fabric internally, you'll need to design a functionally equivalent yourself.
DEAR ALL
Simple answer is you don't. The chipscope ICON is being controlled by software running on the PC through a jtag connection. You can use chipscope to toggle some IOs if that's what you want, but that's not magically going to display characters on an LCD for you. If you want to interface to LCD you will at the very least have to implement that yourself, chipscope won't help there.
