The KS0066 / KS0066U is software compatible to the industry standard HD44780 controller. So you have a very standard LC module.
The only thing that is a little bit different is the fact that the backlight uses only one pin (hence 15 pins, instead of the more common 16). But that should not cause any trouble.
General character LC module info: **broken link removed**
