Jadeit
Member level 5
I have a 180W Chinese motor 6IK 180RGN-CF with the gearbox and this speed controller. The engine stopped turning
There was a cracked and leaking 10uF 450V capacitor in the control unit,. The speed control itself is with a triac.
The motor has three wires, black, red and blue, and two white wires from the back of the speed sensor..
The motor should start even with this connection.
When I measure the resistance between the wires from the motor, it seems that.
black is the common wire for both windings (I measure very little resistance with both blue and red wire)
The problem is, I shouldn't measure any resistance between blue and red, and I measure about 9 Ohms..Does this mean that there is an inter-turn short circuit between the windings and the motor is destroyed or am I mistaken and the whole thing is different?
I tried to start the motor with a 6uF 450V, because it only corresponds to a 100W motor, but there was no other motor capacitor at hand, but even if current passes through the motor, it does not move, and when you turn it by hand, the resistance is still the same.
Štítek motoru
Štítek motoru
