check my codes for PIC18F4520
InNeedOfHelp
Full Member level 3
Full Member level 3
Can anyone help me check whether this code is correct anot ?
//Define .hex file//
#include <p18f4520.h>
#include <usart.h>
#include <delays.h>
//Define Configuration bits//
#pragma config OSC = INTIO67 //Set to use internal oscillator // No external oscillator
#pragma config WDT = OFF    //Turn off watchdog timer
#pragma config LVP = OFF    //Turn off low voltage program
#pragma config DEBUG = OFF  //Turn off debug mode
//Define Function//
void Call_Init_PIC (void);
void Call_Init_USART(void);
void Call_Init_I2C (void);
unsigned char  Get_Temp_Result (void);
void Start_I2C (void);
void Send_To_Slave(unsigned char code);
void Wait_For_ACK (void);
void Restart_I2C(void);
void Switch_To_Read_Mode (void);
unsigned char Load_From_Slave(void);
void Send_NACK(void);
void Stop_I2C(void);
void Display_In_BCD (unsigned char this_number);
//Define Global variable//
unsigned char data;
//Start of Main Function//
void main()
	Call_Init_PIC (); // Call to initialize PIC microcontroller
	Call_Init_USART(); // Call to initialize USART
	Call_Init_I2C ();  // Call to initialize I2C
	while (1)			// run forever; infinite loop
		data= Get_Temp_Result (); //Get Result from TC74
		Display_In_BCD (data); //Display Temperature result in BCD (then convert to ASCII code)
		putcUSART(32); //space
		Delay10KTCYx(100); // one second delay
//End of Main Function//
//////////Supporting Functions//////////
//Some supporting functions for I2C are written for other formats; Write Byte Format, Read Byte Format
void Call_Init_PIC (void)  //initialize PIC microcontroller
	OSCCON = 0x62; //using 4Mhz internal oscillator / No external oscillator
	ADCON1 =0x0f;//; all port as digital I/O pins
	TRISCbits.TRISC3=1; //Set RC3 and RC4 as input
	TRISCbits.TRISC4=1;
	SSPCON1 = 0b00101000; // No collision/ No overflow/ SDA and SCL as serial port/ Clock stretch/ Enable I2C master mode
	SSPSTATbits.SMP = 1; // Disable slew rate control for Standard Speed mode.
	SSPADD = 0x09; // Set Baud rate as 100kHZ
	SSPCON2bits.SEN = 1; // Enable start condition
	while ( SSPCON2bits.SEN)Nop(); // Wait for SEN to go LOW.
	PIR1bits.SSPIF=0; // clear SSPIF flag
	SSPBUF = code;   // Send TC74 ADDRESS; default is 1001101 + (0 write or 1 read)
	while (SSPCON2bits.ACKSTAT); // Wait for ACKSTAT to go LOW.
	while(!PIR1bits.SSPIF)Nop(); // Wait for SSPIF flag to go HIGH
	SSPCON2bits.RSEN = 1;  // Repeated Start Condition Enable bit
	while (SSPCON2bits.RSEN)Nop();  //Wait for RSEN to go LOW.
	SSPCON2bits.RCEN = 1;  // Enable Receive mode
	while ( SSPCON2bits.RCEN)Nop();  // Wait for RSEN to go LOW.
	unsigned char temp;
	temp = SSPBUF; // Load to "temp" variable
	return temp;
	SSPCON2bits.ACKDT = 1;// Send NOT-ACK.
	SSPCON2bits.ACKEN = 1;
	while ( SSPCON2bits.ACKEN) Nop(); // Wait for ACKEN to go LOW.
void Stop_I2C(void)
	SSPCON2bits.PEN = 1; // Initiate STOP condition
	while( SSPCON2bits.PEN) Nop(); //  Wait for PEN to go LOW.
	unsigned char temp;
	//Write According to Receive Byte Format
	Start_I2C ();  //Start Condition
	Send_To_Slave(155)  ;  //Send to slave 7bit Address (1001 101) + RD (1)
	Wait_For_ACK(); //Wait for ACK from slave
	Switch_To_Read_Mode(); //Switch to Read mode in order to receive from Slave
	temp = Load_From_Slave(); //Get data from Slave
	Send_NACK(); //Send NACK
	Stop_I2C(); //Stop Condition
	return temp;
	unsigned char First_Deci; //First Decimal //Local variables
	unsigned char Second_Deci; //Second Decimal
	unsigned char Third_Deci; //Third Decimal
	//the limit of TC74 sensor: +127 to -65 degree
	if (this_number > 127 ) //if more than 127 then go to minus range
		this_number = 256- this_number;
		putcUSART(45); //put minus sign
	First_Deci = this_number/100;
	Second_Deci = (this_number /10)%10;
	Third_Deci = (this_number/1)%10	;
	if (First_Deci != 0){putcUSART(48+First_Deci);}  //Show first digit
		Delay10KTCYx(10);
		if (Second_Deci != 0 || First_Deci != 0){putcUSART(48+Second_Deci);} //Show second digit
		Delay10KTCYx(10);
		putcUSART(48+Third_Deci); //Show third digit
		Delay10KTCYx(10);
		putcUSART(39); //Show "'"
		Delay10KTCYx(10);
		putcUSART(67); //Show "C"
void Call_Init_USART()
		OpenUSART( USART_TX_INT_OFF &
		USART_RX_INT_OFF &
		USART_ASYNCH_MODE &
		USART_EIGHT_BIT &
		USART_CONT_RX &
		USART_BRGH_HIGH,
		25); //Bit per second:9600 / Data bit: 8 / Partiy bit : None / Stop bit : 1 / Flow control : None
Thanks so much
why you are using USARAT and I2C?what is the problem actually?
Im doing a program to display temperature from TC74 to the LCD ..
Ok What is the problem occurring during the execution?
nothing is displaying on the LCD,
Codes is built successfully
i think you are not initialized the LCD in program you have to define that too
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
void main()
 Lcd_Init();                        // Initialize LCD
 Lcd_Out(1,6,"hello");                 // Write text in first row
you also need to send command for lcd what you want to print
Which Compiler are you using? C18 or Hi-Tech C?
Edit: You are using C18. You have to send 0x9A first to I2C. you are sending 0x9B which is d155.
so is send d154 rigght ?
change to d154 at here right ?
	Send_To_Slave(154)  ;  //Send to slave 7bit Address (1001 101) + RD (1)
still cannot display after changing it
#include <usart.h>
#include <delays.h>
#include <i2c.h>
//Define Function//
unsigned char data;
void main()
	TRISCbits.TRISC4=1;
	SSPCON1 = 0x28; // No collision/ No overflow/ SDA and SCL as serial port/ Clock stretch/ Enable I2C master mode
	SSPSTAT=0x80; // Disable slew rate control for Standard Speed mode.
	SSPADD = 119; // Set Baud rate as 100kHZ
	SSPBUF = 0b10011010;   // Send TC74 ADDRESS; default is 1001101 + (0 write or 1 read)
	while(!PIR1bits.SSPIF)Nop(); // Wait for SSPIF flag to go HIGH.
	unsigned char temp;
	return temp;
void Stop_I2C(void)
	unsigned char temp;
	Send_To_Slave(0b10011010)  ;  //Send to slave 7bit Address (1001 101) + RD (1)
	return temp;
		Delay10KTCYx(10);
		Delay10KTCYx(10);
		Delay10KTCYx(10);
		Delay10KTCYx(10);
		USART_RX_INT_OFF &
		USART_ASYNCH_MODE &
		USART_EIGHT_BIT &
		USART_CONT_RX &
		USART_BRGH_HIGH,
Hi Jayanth , it is still not working. any more suggestion ?
i have followed the link already,
