Samuel Onesimus
- Joined
- Feb 24, 2010
- Messages
- 5
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Chennai, India
- Activity points
- 1,333
You need to change the next:
1.- You cannot power all your circuits using the USB power supply, from the USB power supply you can only use 500 mA. Specially if you plan to use Stepper and Servo Motors. Unless the motors require very low current consumption.
2.- Stepper and servo motors cannot be driven directly from an output port, you need a driver for them like an H Bridge.
3.- You need more than one port output to drive a stepper motor, so you cannot drive 6 stepper motors using RA0 to RA5.
4 You need to use a input pin to be able to properly configure the USB, you need a way to let the system know if you are a USB or self powered device.
