ctzof
Full Member level 3
Hello this question was probably made before but I want to ask it from another perspective.
I want to build an inductive linear sensor. The inductance of the sensor changes during movement and this has as a result a change in frequency of an LC tank oscillator. So what I am doing at the moment is to measure the frequency of the oscillator and translate this value to a linear movement.
The method for measuring frequency is simple and has been used a lot. So basically I count how many pulses I have in a certain period of time (1 ms) using a microcontroller counter. My working frequency is 20 MHz at the moment, so so 20500 counts for example means 20.5 MHz.
I don't really care about the exact value of frequency or inductance but more in measuring the change of these values during movement.
My sensor is accurate enough (um) but I want to use alternative ways to measure the inductance-frequency which are faster and maybe less expensive. I should say at this point that the sensor should be able to measure more than one coils at the same time (2-4)
Any suggestions?
Any suggestions?
