What should the range of the output voltage if I am charging a 3.7 li-ion for handphone....
Hi messliaWhat should the range of the output voltage if I am charging a 3.7 li-ion for handphone....
I will be using the voltage regulator 7805 to give out the 5V... do I need limit the output current to follow the current of the battery using a resistor connected to the output
I am using a lm 7805 to charge the battery...
hey,
It say the input voltage to the lm317 to be between 9 V to 12V.. I am to design a circuit based on variable input between 3 V to 12V ....is there was to increase the voltage up and I really I can keep it to a range as I have to take note of the heat dissipated by the lm317
regards,
Messlia
