sunil21
I am trying to charge few lead acid batteries.
few 4.5ah 6v - sealed lead acid battery, a 35ah and 100ah lead acid battery
I have charged the 6v batteries many times before (not properly actually - connecting a 7.5 volt supply to it directly)
I searched on internet and found lot of documents and most of them somewhat differ from each other
voltage level (charge level)
on one site i found below data for 6v (SLA ) battery
100% - 6.30 ...... 25% - 6.0, .... 0% - 6.0
for a 12v battery
100% - 12.6 , 0% - 11.90 etc..
(the above written data, I read it in a web site 1 year back and i cant find it now so may be a slight different)
I have a 100ah Lead acid battery which I have hooked to a solar charge controller and a single panel. The panel is only 120
watts and when it fully charges the battery, controller shows 13.5V and floats. now I doubt it fully charges and i read the
manual and it says never let the voltage drop below 11.0v (the charge controller has set it initially to 10.7v.).Also the manual says to bench charge it once every 3 months of so.. when I connect this battery to 6 amps or more it drops to around 12v(may be due to internal resistance). ignore all the documents, based on your experience tell me what are the SOC (state of charge) and difference between SLA and LA?
I recently bought a CC/CV buck converter on ebay (it says 12amps, but the IC, I checked is rated for 8amps only).I set it up in this way..(for 6v SLA) - connected a 12v 2amp as source, set output voltage to 8v, CC to 500ma (with my multimeter) connected the output terminals to the input of the battery with a single 1N5408 diode beween the output of the buck and the postive of battery (must be around 7.5v after the diode). I have connected the voltmeter directly to the battery terminals.First it is cc mode and then goes to CV, the question is when I stop , what should be the value of voltmeter
for a 12v battery
