dinesh hegde
Member level 2
What type of charges (positive or negative) results in Antenna violations ?
I guess its both, but I need confirmation in actual process.
For a big antenna area I wouldn't rely on it. In such case I used to add a second p+ in n-well diode (n-well connected to VDD, of course).Case2 : If metal is charged with positive ions then, diode is reverse biased, will this current sufficient to discharge the accumulated charges?
Thanks,
Case1 : Metal is charged with negative ions then,
diode is forward biased and it will discharge the accumulated charges.
... If it will be reversed biased, it will have a opening voltage of around -60V (it depends on the technology and diode size)
Whether wafer is grounded during wafer processing steps?
