Hi.
I'm using ultrasclae+ . I want to use the xapp1315 in my design for 1:7 deserialization.
In Xapp1315 design file, an external clock is used to enter the fpga through IBUFGDS.
But in my design, there are many other logics, so xapp1315 design can not be top file.
The main problem is that I have only 50MHz external input clock port, but this xapp 1315 design doesn't support this frequency.
The solution I thought was as follows.
Since the input of IDELAYE3 was no longer coming from the IO buffer, I used a DATAIN port instead of the IDATAIN port.
(I also changed the delay_src from IDATAIN to DATAIN).
However , the simulation results are different from the original xapp1315 design.
The rx_ready signal is not asserted. The output seems as if it continues to bitslip.
Is the way I thought it was wrong?
Is it a problem to create a differential clock in mmcm or is it a problem or is IDELAYE3 misused?
Thank you for reading me the long question.
