change distance unit cm to mm
erwin4838
Member level 1
Member level 1
Tangerang-indonesia
Dear
All my master
i have project with ping sensor this source code for control distance (Jarak) in indonesia language
' CHIP : ATMEGA8535
' CLOCK : 16 MHZ
' LCD : PORTC
' SIG SENSOR : PORTA.1
$regfile = "m8535.dat"
$crystal = 16000000
Dim K As Word , I As Byte , Menu As Byte
Dim Jarak As Word , F_tbl As Bit
Dim Range_min As Word , Range_max As Word
Const E_max = 0
Const E_min = 2
'------- konfigurasi LCD
Config Lcdpin = Pin , Rs = Portc.0 , E = Portc.2 , Db4 = Portc.4 ,
Config Lcdpin = Pin , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7
Config Lcd = 16 * 2
Cursor Off
Cls
Sig Alias Porta.1
Pin_sig Alias Ddra.1
Sig_in Alias Pina.1
Ddrb = &B111
Ddrd = &B0000
Portd = &B1111
Readeeprom Range_max , E_max
If Range_max = &HFFFF Then Range_max = 0
Readeeprom Range_min , E_min
If Range_min = &HFFFF Then Range_min = 0
Lcd "Jarak="
Lowerline
Lcd "Min=" ; Range_min
Lcd " Max=" ; Range_max
Do
   Gosub Ukur_jarak
   Locate 1 , 7
   Lcd Jarak ; " cm "
   If Jarak >= Range_min And Jarak <= Range_max Then
      Portb = &B001
   Elseif Jarak > Range_max Then
      Portb = &B010
   Elseif Jarak < Range_min Then
      Portb = &B100
   End If
   For I = 0 To 200
      Gosub Cek_tombol
      Waitms 4
   Next
Loop
End
Cek_tombol:
Do
   If Pind.0 = 0 And Menu = 1 Then
      If Range_min > 0 Then
         Decr Range_min
         Locate 2 , 11
         Lcd Range_min ; " "
         Writeeeprom Range_min , E_min
         Waitms 250
      End If
   Elseif Pind.1 = 0 And Menu = 1 Then
      Incr Range_min
      Locate 2 , 11
      Lcd Range_min ; " "
      Waitms 250
   Elseif Pind.0 = 0 And Menu = 2 Then
      If Range_max > 0 Then
         Decr Range_max
         Locate 2 , 11
         Lcd Range_max ; " "
         Writeeeprom Range_max , E_max
         Waitms 250
      End If
   Elseif Pind.1 = 0 And Menu = 2 Then
      Incr Range_max
      Locate 2 , 11
      Lcd Range_max ; " "
      Waitms 250
   Elseif Pind.2 = 0 And Menu = 0 Then
      Menu = 1
      F_tbl = 1
      Cls
      Lcd "Seting Range Min"
      Lowerline
      Lcd "Range Min=" ; Range_min
   Elseif Pind.2 = 0 And Menu = 1 Then
      Menu = 2
      Cls
      Lcd "Seting Range Max"
      Lowerline
      Lcd "Range Max=" ; Range_max
   Elseif Pind.2 = 0 And Menu = 2 Then
      Menu = 0
      F_tbl = 0
      Cls
      Lcd "Jarak="
      Lowerline
   End If
   If Pind.3 = 0 Then
      Menu = 0
      F_tbl = 0
      Range_min = 0
      Range_max = 0
      Cls
      Lcd "Jarak="
      Lowerline
      Waitms 250
   End If
Loop Until F_tbl = 0
Return
Ukur_jarak:
   Pin_sig = 1
   Sig = 0
   Jarak = 0
   Sig = 1
   Waitus 5
   Sig = 0
   Waitus 760
   Pin_sig = 0
   Sig = 1
   Bitwait Sig_in , Set
   For K = 0 To 400
       If Sig_in = 1 Then Incr Jarak
       Waitus 58
   Next
   If Jarak > 300 Then Jarak = 300
Return
with code on only can measures multiple 1 cm, can not read distance under 1 cm, i am the aid request so that censor can read in unit mm, for example reads distance 0,50 mm, thank for your kind attention:)
