I have a center tap toroidal Transformer transformer with 14.5V-0-14.5 (RED BLACK RED) outputs.
the input is 220V AC and the output 14.5V-0-14.5 (RED BLACK RED).
If im just using the black and 1 red wire I get around 16V same as the other red wire. but when I connect them in series to get around 29V the transformer get very hot and make some small sparks and doesnt give me any output voltage. as I said if I'm not connecting 2 of the wire in series, nothing happens and the transformer is happy.
my question is why the transformer shorts out or something? can't I connect the wires in series to get 29V or what?
here is a picture of the transformer with the label on it :
Thanks for everyone who is trying to help.
What are you connecting "in series"? With no load then the output is about 16V from one red secondary wire to the black center-tap wire and there will be another output of about 16V from the other red wire to the black wire. If you want 32V (29V with rated load) then it should be between both red wires then the black wire is not connected to anything.
NEVER connect the two red secondary wires together.
