[SOLVED] CD4046 VCO design, PLL parameters and it did work
elisemark
Junior Member level 1
Buffalo, NY
VCO frequency problem
in my circuit design I am sending an oscillator output signal into a CD4046 PLL, the oscillator frequency is around 850KHz, now I calculated all the PLL parameters well and it did work for a while then now I have a nice square wave(@310KHz free running) as soon as I connect the oscillator signal then I loose the VCO signal ( 0 volts) then after a few seconds the VCO signal becomes a flat DC signal at around 4.5V.
1. any idea why this is happening
2. also should I expect the VCO value at pin 4 of the CD4046 to be near 850KHz with no signal input connected ( free running VCO) ? R=10K and C=470pF.
the loop filter is designed with a cut off frequency just below 50Hz.
Thanks for any feedback
Re: CD4046 VCO design Problems
Thanks IanP , the documentation you pointed to is very helpful
please if some has an access to IEEE explore i need this too papers:
-A Differential Output Delay Cell Based Ring VCO for Improved Jitter Performance
Singh, G.K. Jamadagni, H.S.
Pulsecore Semicond. (I) Pvt Ltd., Bangalore
This paper appears in: International Symposium on Integrated Circuits, 2007. ISIC '07.
- Design of 2 Stages Ring Oscillators Applying Local Networks of Feedback
Colin, D.D. Sanchez, A.D. Aranda, M.L.
Nat. Inst. for Astrophys., Opt. & Electron., Puebla
This paper appears in: 18th International Conference on Electronics, Communications and Computers, 2008. CONIELECOMP 2008,
could some one help me
thanks for any feedback
