CCS C Compiler problem
john120
Banned
Full Member level 5
can you plz help me to solve the problem of my compiler which,when I compiler my file anme file.c the compiler opens another file 16f877a.h and then it displays many errors;can you plz help me to solve the problem.
Thanks.
file -> close all
project -> new -> project wizard
choose your microcontroller
choose the c file to be added to the project.
then compile the program.
Unfortunately it is not running I closed everything but it is not operating.And also I open my saved file on the disk (creaated using Proteus);I reopen it ,but after some 5-15seconds it closes it self.
Tell me what to do.
Remove the main directory
program files -> PICC folder
remove the PIC C from the registry
restart the computer
reinstall the software
In run command
type : "regedit" and press enter
click on "HKEY_LOCAL_MACHINE" (which is located at left panel)
your can find "software" and click on it
now you can find "ccs inc." file
right click and delete.
if didn't find the above mentioned file, restart the system and install the fresh copy of the software.
I didn't get this statement
Reactions: PA3040
    PA3040
I wonder what you want to achieve?
I would expect an error in the compiled project in a first order.
CCS C V4.068 is a very old version that has some errors. I wonder if it's from an outdated pirate bay.
Dear All
sorry for come to the middle of the tropic
Does CCS support for PIC16F ( Mid rage )?
Please advice
Thanks in advance
I think CCS C and MPLAB C are different
I misunderstood both as one product
Thanks for advice
