nomenclator
Newbie level 1
- Joined
- Dec 5, 2009
- Messages
- 1
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Long Island, NY
- Activity points
- 1,296
According to my understanding, in LCD televisons and computer monitors: the fluoresecent backlight lamp gets AC power from an inverter; the invertor has changed low voltage dc power to high voltage ac power (around 12 volts dc to something like maybe 30,000 vac); the low voltage dc power for the inverter input is provided by a power supply device, which provides dc power for everything in the LCD video device that needs power; and the power supply device converts 120 volts ac, to several different dc voltages, negatively or positively going, relative to ground, as required.
My question is why first convert ac to dc, then back again to ac? Obviously I don't know much about this subject, but common sense would tell me that a device that converts 120 vac to 30,000 vac be simpler to design and manufacture, and require less components to make it work, than a device that not only steps up the voltage, but also has to convert dc to ac? Why is my common sense misleading me? Don't ac inverters require a whole extra section to convert the low vdc to high vac, that could be left out if the high vac power for the ccfl, was obtained from a device that converts low vac to high vac, basicly a transformer with a regulated ac output?
It isn't like the LCD video device is going to be used somewhere where 120 vac isn't available. It is there? If you have ac available, why convert ac to dc, then back again to ac?
