cc1010 new super 300-1000 mhz rf transceiver chip by chipcon
bumerang
Member level 2
Member level 2
rf super transceiver
I want to announce cc1010 rf transceiver chip with integrated microcontroller
chip specs;
300-1000 MHz RF Transceiver
•Very low current consumption
•High sensitivity (typically -107 dBm)
•Programmable output power up to +10 dBm
•Data rate up to 76.8 kbit/s
•Very few external components
•Fast PLL settling allowing frequency hopping protocols
•RSSI
•EN 300 220 and FCC CFR47 part 15 compliant
•8051-Compatible Microcontroller
•Typically 2.5 times the performance of a standard 8051
•32 kB Flash, 2048 + 128 Byte SRAM
•3 channel 10 bit ADC, 4 timers / 2
PWMs, 2 UARTs, RTC, Watchdog,
SPI, DES encryption, 26 general I/O
pins
•In-circuit interactive debugging is
supported for the Keil µVision2 IDE
through a simple serial interface.
•2.7 - 3.6 V supply voltage
•64-lead TQFP
www.chipcon.com
