[SOLVED] Capacitor Transient Response Simulation in Proteus
ln30356
Hi everyone,
I 'm learning about Capacitor Transient Response, and I got problems in simulating in proteus.
I have a circuit in figure (a). At the time switching from open to close, there's a transient voltage at capacitor. I'm searching many way to get the graph described in figure (b), but not successfully. Can you tell me how I can get this from simulation in proteus?
By the way, as simulating (figure (c)), at the first time, I realize that the voltage between capacitor plates is 15 V even the switch haven't been closed yet. It seems to me that the capacitor has been already charged. I don't get why that is. Can you explain this to me?
Thank you.
Figure (a)
Figure (b)
Figure (c)
Proteus file
View attachment AllaboutCircuit.rar
Try the attached simulation file. It is in Proteus 8.3 SP2 format.
You should not press simulation button at the bottom left. Instead you have to right click on the Graph and choose Simulate Graph.
  • AllaboutCircuit.rar
I guess, specifying the switch closed at t = 0 means it's already closed at startup. Should specify a very small time offset.
Secondly minimum conductance constraints of the SPICE simulator might cause a problem in some cases. Adding a gohm leakage resistor the the capacitor might help.
Finally, check that the switch doesn't have a finite Roff value.
I think you have to change the capacitor model. I have used Animated Electrolytic Capacitor.
Thank you for your answer. I think the problem is that I chose the wrong capacitor. The circuit function as expected when I replace the capacitor. I still want to keep the button to see the result as described in figure (b) (of my last post), so I have to use the interactive analysis.
Thanks for your reply
In my circuit it has taken 400 ms to charge fully. So set the Oscilloscope timebase for 350 ms and use Oscilloscope to plot the graph.
Hi, thank for your suggestion.
I think the difference is that in first capacitor using case, the capacitor has been already charged at the first moment (figure a), while in second one, the capacitor has not been charged yet (figure b). By the way, can you tell me if there is any way to export value from the oscilloscope so that I can do some comparison with transient analysis?
Figure a
Figure b
Proteus
Thank you.
You can save the oscilloscope output (graph) as a PDF file.
my proteus version is v8.1
and With its implementation does not change in interactive graph!!!
and just components change
please Once fully explain.
