danielclark
Newbie level 1
generating saw tooth signal
Hi guys, I am using a PIC Micro to generate a signal of 11hz per second (i.e. it pulses 0 and 1 eleven times per second), which will generate a squarewave signal.
I want to modify the signal to output a 'sawtooth' signal. How do I calculate the capacitor value to use?
Is there a formula to use where I input Voltage, frequency etc.
Thanks
Thanks
