[SOLVED] -------------------capacitive load in ---opamp.
shinulalu6
how to find out the maximum CL that can be considered across the op-amp?
in which configuration we have to use the opamp in order to find out the maximum CL and IL?
To know more, find and read the complete specifications of your opamp. Many indicate what happens when the load is capacitive, and some opamps are designed to be loaded with larger capacitors.
i got ur point.......suppose i have designed the opamp for some CL,,,i need to check what is the maximum capacitance( greater than CL) still that is allowed in which opamp remains stable.
for this which configuration i have to use in order to get this max CL?
i hope u got my question...
