can't save&load simulation state1,2,3...in artist_states
xiaohuoshuan
Newbie level 1
procedure(sevdirfiles(name))
need your help! I can't save&load my simulation state in spectre artist_states cadence 5033.
.artist_states cadence
If this menu item is grayed out, you should check your ADE license.
cadence artist_states
If you run ic5141 in Fedora or some latest linux platform,you may meet the problem of saving states. You can't load the states named as state1,2,3..., but the states named as other can be loaded normally.The reason seems to be the next:
Fedora have a different data storage style.
Specifically that problem you can resolve by entering to .cdsinit the next line
procedure(sevDirFiles(name)
(cdr (cdr (sort (getDirFiles name) nil)))
Good Lucy !
.artist_states
Thank you so much, xdlile!
Good Lucy !
