andy40185
Member level 5
Hi all,
I am a java newbie and I'm using NetBeans IDE 7.2.1. The complier reported that the file cannot find.
I have attached the file (match.wav) in my project folder.
This is my code.
Regards,
Andy
This is my code.
package GemCrush;
import java.awt.Component;
import java.io.*;
import java.net.MalformedURLException;
import javax.sound.sampled.AudioInputStream;
import javax.sound.sampled.AudioSystem;
import javax.sound.sampled.Clip;
import javax.sound.sampled.LineUnavailableException;
import javax.sound.sampled.UnsupportedAudioFileException;
import javax.swing.JFileChooser;
import sun.audio.*;
public class Sound {
private Clip clip;
public Sound(String fileName) {
// specify the sound to play
// (assuming the sound can be played by the audio system)
// from a wave File
try {
File file = new File(fileName);
if (file.exists()) {
AudioInputStream sound = AudioSystem.getAudioInputStream(file);
// load the sound into memory (a Clip)
clip = AudioSystem.getClip();
clip.open(sound);
else {
throw new RuntimeException("Sound: file not found: " + fileName);
catch (MalformedURLException e) {
e.printStackTrace();
throw new RuntimeException("Sound: Malformed URL: " + e);
catch (UnsupportedAudioFileException e) {
throw new RuntimeException("Sound: Unsupported Audio File: " + e);
catch (IOException e) {
throw new RuntimeException("Sound: Input/Output Error: " + e);
catch (LineUnavailableException e) {
throw new RuntimeException("Sound: Line Unavailable Exception Error: " + e);
// play, stop, loop the sound clip
public void play(){
clip.setFramePosition(0); // Must always rewind!
clip.start();
public void loop(){
clip.loop(Clip.LOOP_CONTINUOUSLY);
public void stop(){
clip.stop();
public static void main(String[] args) {
Sound s = new Sound("match.wav");
s.play();
Regards,
Andy
