Hi all,
I downloaded tinybootloader, designed a circuit required for it on a matrix board. The circuit diagram is attached below. In the tiny booloader folder, there was a picsource folder which contained several hex files. The one required for me was 'tinybld_16F876A_20MHz' as I am using PIC16F877A. I burnt this hex file to my PIC using PICKIT2. I didnt include those 3 '.inc' files located in the picsource folder. I also havent used the RESET button in the MEMCLR pin (pin1) but I have connected it to Vcc through a resistor. After burning, I arranged the connection and executed tinybootloader. I set my baud rate to 9600 and corresponding COM port was selected. On Pressing 'CheckPIC' button, an error is generated. I have posted the snapshot of that particular error. Please help me find what is cause of this error? I tried using other baud rates too but it didn't work.
