Thank you it works.
Now I just put the code for blinking LED code as the clock generator, and then check the signal at the Oscillosope, but the signal worse, It is some worst distorted shape of the sine wave sort of something. It is good to glow the LED but not suitable for the Clock, what do you guys suggest for the clock.
I have read some where using PWM something can be done, but I think Blinking LED code should work as the clock generator since it is just ON/OFF..
by the way, if I am not mistaken, the output of PIC is TTL based.
Bests,
jaffry
any idea please ...!
