Re: Can we use normal buffers instead of clock buffers for C
hi,
if u don't have clock buffers and inverters, then check the buffers and inverters cells in your library and check their drive strength, rise time and fall time. its advisable to use the buffers and inverters having nearly same rise and fall time event for clock tree, next it should have high drive strength and good slew. So with this checks you can use proper buffers and inverters for clock tree.
it may help you.
thanks..
HAK..
