[SOLVED] Can we use 16F628a instead of 16F627a???
rohith
Newbie level 5
Hai.....
Can we use 16F628a instead of 16F627a??? if not why?
give alternate for 16F627a?
Hai.....
what kind of system you are going to build all that depends.
i am building a rgb mood light..
you can implement any one of this, both are 18 pin IC.
The 628A is a direct substitute for the 627A. They are the same device, only the amount of memory is different and as the 628A has more, there shouldn't be any problem.
Brian.
Reactions: rohith
    rohith
