Can this diode forming bridge diode for the 24VAC to 12VDC circuit?
That's the only differences. Thus there's no reason or advantage in using a Schottky diode for converting 24VAC to 12VDC from mains since you have voltage to burn and the rectification frequency is low.
Should not be a problem , provided you are using a bridge(4 diodes).
If you are using 2 diodes with a center tapped transformer , you may exceed the
peak reverse voltage of the diode.
Neddie
