Can someone provide me an (ADC) with the given specs:
howie
Member level 2
Philippines
Can someone provide me an Analog-to-Digital Converter (ADC) with the following specifications:
a. 8-bit conversion
b. Atleast 8 channel inputs
c. Can measure both Voltage and Current
d. Analog Voltage Input range: Ateast 0-5Vac
e. Current Range: 0-40mA, 0-30mA
f. If possible, can be interfaced in a processor (SPI)
Thank you.
you can go for a microcontroller with adc, most adc will do with volt and for current you have to convert current to volt. and can be interfaced with SPI if needed( any way you want if you need the adc part)
Hi!
May be the best way is to use ADC board from the industry.
There are a lot of them with a lot of useful features.
And they are tested and ready to run.
Sometimes there is a build in MCU and useful software with them.
BR
