ozgur85
Member level 1
- Joined
- Aug 21, 2013
- Messages
- 32
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 6
- Activity points
- 288
Hello everyone
I know there are electronic geniouses here and can make a high power laser driver+PS circuit with no problem at all.
I have been wanting to buy a super pulsed laser device but i can't find them or they are very very expensive.
I want to make a device with 4 Osram SPL_PL90_3 lasers. 60W peak power each. 100ns pulses. Duty cycle %0,1. Appropriate pulse frequency to achieve 60mW average power.
I can buy the laser diodes. I want to "buy" a driver with PS circuit (which can be put in a box that has 51mm x 81mm x 30mm dimensions.) from YOU (someone who can do it!) with paypal payment.
I have two of those boxes. I can find bigger boxes also but not much big. I will glue the 2 boxes together. I will drill 4 holes for the laser diodes. I will put the driver with the PS inside the other box.
So i want that the only thing i must do is to connect the lasers cables to the driver. And connect the PS's cables to AC. I guess you understand what i mean.
Here is the example:
Can someone do this so i buy it from him?
By the way, the device should work at 110V and 220V..
