can PIC12C509A lose its programming
testep11
Cyprus
Hi everyone
can a PIC12C509A lose its programming,when connected wrong in a circuit?
i use it with a MICRF001 and seems that the PIC12C509 don't work. I order it and sent to me fully programmed for the purpose i need it.
amraldo said:
By the way why are you using the Analog IC Design & Layout forum? Amt
MOD: The topic is now moved to Microcntroller section. Next time you'll be warned. Post in respective Forum.
May be it is corrupted.
-By the way why are you using the Analog IC Design & Layout forum?
Amt
