can microcontrollers run these kinds of lcds ?
ambition
Junior Member level 2
very simple question
at apollo displays : https://www.apollodisplays.com/
(at the right side = 15'' all-in-one displays
my question , can microcontrollers (PICs or any other kind) run these kinds of lcds?
Or the same lcds monitors that are used along with computers ??
any help?
Your assumption is correct.
Hi
To drive large lcds
infact most lcd's that are tft based
you need to use a fast vdac {video digital to analogue converter}
you can do this but you need to use 16bit drive
and not pic mcu you need a faster core around 40mhz
some types will run ok from senix chips
but your by far better using fpga or gate array logic
