can i use the Control pin of 555 timer to change duty cycle without changing the set?
Amalinda
Banned
Full Member level 1
can i use the Control pin of 555 timer to change duty cycle without changing the set frequency?
to be more precise,
i want to set a frequency in the circuit using a potentiometre. and when i change the potentiometre_2 the duty cycle must change without causing a change in frequency. I doubt if this is doable using 555.
if not,
Is there a way using op amps?
thank you.
To demonstrate the result of what is described in the thread title...
Here is a screenshot showing the effect of a range of volt levels at the control pin of a 555.
It looks as though there is a range where the duty cycle changes yet the frequency is the same.
As a higher voltage is applied it is obvious the frequency gradually gets slower.
