selva murugesan
can i use reset pin as a input in atmel? i used as input pin,but it doesnt work properly.
4. When programming the RSTDISBL Fuse Parallel Programming has to be used to change
fuses or perform further programming
RESET, Reset pin: When the RSTDISBL Fuse is programmed, this pin functions as a normal I/O
pin, and the part will have to rely on Power-on Reset and Brown-out Reset as its reset sources.
When the RSTDISBL Fuse is unprogrammed, the reset circuitry is connected to the pin, and the
pin can not be used as an I/O pin.
If PC6 is used as a reset pin, DDC6, PORTC6 and PINC6 will all read 0.
