can i use pull up resistor on pwm pins
raman00084
Full Member level 6
Full Member level 6
i am developing dspic board it operates at 5v level. my doubts is can i use 10k upllup resistor on pwm pins, spi pins , uart tx/rx pins and qei(A,B, INDEX). ?
regards
KALYAN
Use pull-up resistors to achieve exactly what? I presume you mean pull-up to 5V. Are you using a 3.3V or 5V dsPIC?
It only makes sense for input and open drain output pins. Some of the mentioned pins are push-pull outputs, so a pull-up resistor would be useless. If you are using pull-ups to 5V with a 3.3V dsPIC, take care that the respective pins are 5V-tolerant.
It would make sense if the OP is trying to maintain a high state on the output until the processor starts up, regardless of whether they're push-pull outputs or not. A lot of devices start up with the outputs tri-stated (not sure about the dspic)
Yes, in case of the outputs. But this point won't be particularly related to 5V operation. In wonder if the original post is just unclear or intentionally mixes unrelated design objectives?
That would never happen on the edaboard!
Is there is any harm in using pull up on pwm pins because some projects i will use the pwm pins as io and for other project as pwm. So can i use pull up? My ds pic works on 5v supply
