carlos_elt said:I found a schematic of a wiggler jtag in the net it is attached.
carlos_elt said:Hey dainis,
I didn't knew it wasn't full compatible with wiggler can u post a schematic of a full compatible jtag wiggler please?
Without detailed view, this look more similar with original Wiggler. I do not test any Wiggler with IAR ...carlos_elt said:So dainis if i use this schematic (h**p://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/wiggler1.pdf) and connect pins 8 and 15 of the DB25 the TMS470 will work just fine with code composer or IAR ?
vinicius said:Hi dainis can u post the schematic of yours wiggler ? Just to make sure i'm building it right thanks
vinicius said:Thanks for the schematic but, sorry i'm just beginning to work with ARM devices, i would like to know if the code composer for TI just simulates a TMS470 or can also program a device with a wiggler like that? thanks again
vinicius said:Dainis but the software u pointed to use with yours wiggler doesn't goes with the TMS470 at least it wasn't listed neither on the site nor on the program itself as philips and others.
P.S.: I want to use TMS470 because of its inbuilt interfaces for OBDII and because of its great flash memory that is said to reach 1mb next year
samir mistry said:i have tried to use wiggler(working ok with lpx21xx) on tms470 in rowly crosswork software but it does not seem to be working,If you are having any tested wiggler circuite for wiggle for tms470?
Thanks in Advace
samir
nooknikz said:**broken link removed**
