Can I use ".nodeset" in Hspice control file when A
purefen
Junior Member level 1
.nodeset+hspice
Dear All:
Can I use ".nodeset" in Hspice control file when AC analysis.
Because I simulate the large circuit, and it cannot converage, as the result, I use the ".nodeset" . But I feel it may get wrong result.
BR. purefen
hspice .nodeset
You can use .IC instead to get the circuit converge.
When I have that kind of problem I first do a transient simulation with .tran UIC to make the startup of the circuit. After the circuit is in the correct operation point I save all the node voltages with .OP "some time". After this you can do the AC including the OP.ic file.
Hope that helps.
Bastos
nodeset ic hspice
.nodeset forces the simulator to start with nonlinear DC iteration at a specific point. If there is more than one DC solution you can select via .nodeset one of the possible solutions. Try it with a register cell. But .dc will force the node independ of a correct solution without this force value. So the result of your AC could be wrong. If you use a voltage source instead of a .dc you have the same effect. But you can observe how much current flow through the force source. If it nonzero the reslutl in inaccurate.
