AlienCircuits
Member level 5
This is possibly a stupid question, but is it possible to use a flyback transformer as a forward converter transformer? It seems like a reset winding is an optional method for resetting the core for forward converters, so could I use a flyback and reset the core a different way and be fine with a forward topology?
Also, when I see flyback transformers rated for an input of 36-72V, they are usually for applications that need 3.3V, 1.8V, etc. on the secondary side. Should I take this 36-72V input voltage as an electrical rating, or should I use the insulation voltage rating because those input voltages are only in the context of the application?
