May 2, 2007 #1 N netfirms Newbie level 4 Joined Apr 21, 2007 Messages 7 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,281 Activity points 1,314 arm7 + mmc is it same way with MCS51:| . i must use ARM7 to control Ethernet module in my project and i want to storage datalog in MMC . How can i do?
May 4, 2007 #2 mitaka Member level 3 Joined Feb 18, 2003 Messages 57 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Location Bulgaria, Canada Activity points 437 reading mmc arm7 you can use LPC2378 from NXP - it has MMC driver and ethernet. check MCB2370 Evaluation Board from Keil
May 5, 2007 #3 bobcat1 Advanced Member level 4 Joined Jul 10, 2002 Messages 1,284 Helped 99 Reputation 198 Reaction score 34 Trophy points 1,328 Activity points 8,546 efsl arm7 Hi Search google for EFSL - they have port for arm7 for reading and writing file to MMC & SD card All the best Bobi
May 5, 2007 #4 B bbbb Member level 2 Joined Apr 24, 2006 Messages 47 Helped 12 Reputation 24 Reaction score 1 Trophy points 1,288 Activity points 1,526 mmc arm7 You can also use the SPI interface of any processor to communicate with a MMC.
May 24, 2007 #5 P photonix Member level 2 Joined Mar 15, 2005 Messages 45 Helped 4 Reputation 8 Reaction score 0 Trophy points 1,286 Activity points 1,550 Of course you can. You can interface MMC/SD with SPI interface and then read/write raw data on it. If you need to create/read/write using files you need to implement FAT filesystem.
Jun 7, 2007 #6 P Prabakaran Full Member level 3 Joined Jan 22, 2007 Messages 167 Helped 9 Reputation 18 Reaction score 3 Trophy points 1,298 Location Chennai(India) Activity points 2,273 Can i use the same MMC with Atmel Series if so whether i have write any device driver for that?
Jun 7, 2007 #7 V vijayragavalu Member level 1 Joined Aug 29, 2005 Messages 36 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,558 is it same way with MCS51:| . i must use ARM7 to control Ethernet module in my project and i want to storage datalog in MMC . How can i do? Click to expand... check this link http://www.techtoys.com.hk/
Jul 20, 2007 #8 mitaka Member level 3 Joined Feb 18, 2003 Messages 57 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Location Bulgaria, Canada Activity points 437 I've tried EFSL with ARM and SD_MMC card interface and it's working. So go for it
Jul 22, 2007 #9 Taro Full Member level 2 Joined Jun 28, 2001 Messages 143 Helped 8 Reputation 16 Reaction score 5 Trophy points 1,298 Activity points 1,195 If you use LPC214x, EFSL will very useful and make your job become very very easy. So, Let's try it as soon as you can.
