Circuit Learner
Junior Member level 1
I bought a Dc-Dc converter which has an adjustable voltage range of 1.25-36V. This is the unit I bought below.
https://www.amazon.com/DROK-Regulat...adjustable/dp/B00C4QVTNU/ref=cm_cd_al_qh_dp_i
However the input range is 5-40V DC.
The unit has 5 caps rated at 330UF and 50Volts. If I replace the caps with 330UF 100 volt caps, will this allow me to use the unit at 72 volts input voltage?
I see what looks like 2 fets on the board, I am not sure if those have a voltage limitation.
Thanks.
Thanks.
