Can I do this in VHDL?
barry
Advanced Member level 7
California, USA
Maybe I'm trying to do something I can't, but it seems like I should be able to.
Here's a snippet:
signal big:std_logic_vector(15 downto 0);
signal little:std_logic_vector(3 downto 0);
little<=(big-x"0010")(3 downto 0);
This is part of a testbench I'm using in Active-HDL, and it doesn't like the assignment. The error I get says it wants a ";" before the "(3 downto 0)". If I eliminate the "(3 downto 0)", it compiles ok, but then fails at runtime (as would be expected).
Any thoughts, guys?
Hmm, I always thought you could, but apparently not.
However, you can slice a function return, rather than an operator
Code VHDL - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
library ieee;
use ieee.std_logic_1164.all;
--use ieee.std_logic_unsigned.all;
use ieee.numeric_std.all;
entity test is
end entity test;
architecture rtl of test is
  signal a : signed(15 downto 0);
  signal b : signed(3 downto 0);
  function minus(a : signed) return signed is
  begin
      return a - 1;
  end function;
begin
  b <= minus(a)(3 downto 0);
end rtl;
Reactions: barry
    barry
Thanks Tricky
Just thought it would be nice if it worked MY way.
This might actually be a problem with the active-HDL compiler. Since it's a testbench, I haven't tried to synthesize it. I might just do a test to see if it synthesizes.
It failed in modelsim for me, so I assume its a language thing.
Haha
First try AHDL then get really mad...
