Terminator3
Advanced Member level 3
Is it good idea? What should i do else? Short-circuit stubs at f0 on output and 2f0 at input to filter out?
Thanks!
Thanks!
Note: This feature currently requires accessing the site using the built-in Safari browser.
I think its perfectly possible theoretically
a full wave rectifier will double the frequency. And if balanced, it will not leak out too much fundamental frequency (a good thing if you need a broad frequency range of coverage). But they are lossy...you should expect at least 8 dB of conversion loss.
You can get maybe 1 dB of conversion loss if you use a properly designed varactor X2. And active multiplier can have conversion gain, but watch what it does to the noise floor!
