ericmar
Full Member level 5
icsp mode
Hi all,
Is it possible for me to combine the circuit in https://www.olimex.com/dev/images/pic-pg1-sch.gif with my PIC device so that I can program my PIC directly? I got serial communication in my original circuit, so is it mean I'll need to share the RS232 transmit line when I combine both this circuit with my original circuit?
It was stated in https://www.olimex.com/dev/pdf/pic-pg1a.pdf that MCLR should not be directly connected to Vcc as programmer try to rise MCLR to 13VDC to enter in programming mode. So wat should I do if my original circuit connects the MCLR directly to Vcc?
I'hv an idea but I'm not sure if this will work or not. I was thinking that maybe I can add a switch or relay and whenever I want to do ICSP, all I need is to activate the switch and turn on the ICSP circuit. Am I on the right track?
Question and answer merged into one post.
Cluricaun
Thanks a lot!
Regards,
Eric
Hi all,
Cluricaun
Thanks a lot!
Regards,
Eric
