[SOLVED] Can fully differential op amp be connected as buffer?
jdp721
Member level 2
Member level 2
Hi.
Can a fully differential op amp be used as a unity-gain buffer, in some manner as we use a single-ended opamp:
If yes, how to connect up the circuit?
With -1 gain, yes. But to make noninverting differential buffer You need FDDA (Fully Differential Difference Amplifier - 4 inputs, 2 outputs)
Reactions: jdp721
    jdp721
Hi Dominik (and other members :)
Can the fully diff opamp be connected like below?
Thanks,
jdp
Yes, One has to cover rail to rail operation at input and use differential output stage.
No. Connect +out to -in, and -out to +in .
I'm not completely clear about the purpose of this circuit, e.g. where goes the input signal? Analog has suggested a few unusual circuit with fully differential OP in the AD8132 datasheet. They depend in part on the frequency characteristic of the common mode feedback circuit.
  • AD8132 Circuits.pdf
Reactions: jdp721
    jdp721
