And the task is to display the string in lcd after it should increment to the next cursor continously once it displayed the entire string
* Project name:
Lcd_Test (Demonstration of the LCD library routines)
* Copyright:
(c) Mikroelektronika, 2011.
* Revision History:
20110929:
- initial release (FJ);
* Description:
This code demonstrates how to use LCD 4-bit library. LCD is first
initialized, then some text is written, then the text is moved.
* Test configuration:
MCU: PIC18F45K22
http://ww1.microchip.com/downloads/en/DeviceDoc/41412D.pdf
Dev.Board: EasyPIC7 - ac:LCD
http://www.mikroe.com/easypic/
Oscillator: HS-PLL 32.0000 MHz, 8.0000 MHz Crystal
Ext. Modules: Character Lcd 2x16
http://www.mikroe.com/store/components/various/
SW: mikroC PRO for PIC
http://www.mikroe.com/mikroc/pic/
* NOTES:
- Turn on Lcd backlight switch SW4.6. (board specific)
// Lcd module connections
sbit LCD_RS at LATB4_bit;
sbit LCD_EN at LATB5_bit;
sbit LCD_D4 at LATB0_bit;
sbit LCD_D5 at LATB1_bit;
sbit LCD_D6 at LATB2_bit;
sbit LCD_D7 at LATB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End Lcd module connections
char txt1[] = "mikroElektronika";
char txt2[] = "EasyPIC7";
char txt3[] = "Lcd4bit";
char txt4[] = "example";
char i; // Loop variable
void Move_Delay() { // Function used for text moving
Delay_ms(500); // You can change the moving speed here
void main(){
ANSELB = 0; // Configure PORTB pins as digital
Lcd_Init(); // Initialize Lcd
Lcd_Cmd(_LCD_CLEAR); // Clear display
Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
Lcd_Out(1,6,txt3); // Write text in first row
Lcd_Out(2,6,txt4); // Write text in second row
Delay_ms(2000);
Lcd_Out(1,1,txt1); // Write text in first row
Lcd_Out(2,5,txt2); // Write text in second row
Delay_ms(2000);
// Moving text
for(i=0; i<4; i++) { // Move text to the right 4 times
Lcd_Cmd(_LCD_SHIFT_RIGHT);
Move_Delay();
while(1) { // Endless loop
for(i=0; i<8; i++) { // Move text to the left 7 times
Lcd_Cmd(_LCD_SHIFT_LEFT);
Move_Delay();
for(i=0; i<8; i++) { // Move text to the right 7 times
Move_Delay();
